Forums >> Community >> Newbies >> Cant constrain Revit families inside of building
Wed, Dec 10, 2014 at 1:33:08 PM | Cant constrain Revit families inside of building
kschoe
I am new to Revit, I am not having much luck constraining families inside of my building model to keep them in place.
We mount car wash equipment inside of buildings, I can't believe that Revit won't allow me to constrain and adjust
equipment inside of the building. Any tips would be appreciated.
Thanks in advance.
Wed, Dec 10, 2014 at 1:49:32 PM | Cant constrain Revit families inside of building
You can constrain pretty much everything in Revit.   You need to spend some time with tutorials and instructional videos.  You should also learn to use the built in HELP.   It is very easy - Just hit the ? on the right/top of your screen.   A simple searh 'constrain' brings up a lot.  Read this one:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-E66946AE-64B0-448D-8357-65F30F643F39
Wed, Dec 10, 2014 at 1:52:35 PM | Cant constrain Revit families inside of building
kschoe
Thanks for the link and the tip!
Wed, Dec 10, 2014 at 2:09:37 PM | Cant constrain Revit families inside of building
kschoe
  • Dimension Cannot Be Made Constraining
    Dimension Cannot Be Made Constraining Warning: The dimension cannot be made constraining. Issue: While creating a family, you have tried to make a reference dimension constraining. Solution: You cannot turn a reference dimension into a constraint.
    2012-03-26
This is what I am running into.  I am used to constraining items with dimensions so they can be adjustable.
Thanks in advance for any tips
No light inside building
Thu, Mar 29, 2012 at 3:52:35 PM
Inside Rendering
Fri, Jun 12, 2009 at 12:42:25 PM
Window with different head height on inside and outside
Wed, Sep 3, 2008 at 1:42:11 PM
Is it a good practic to embedde text label inside REVIT family?
Thu, Feb 13, 2014 at 9:27:12 AM
Filled regions inside of families.
Tue, Feb 8, 2011 at 6:42:32 PM
Page generation time: 4.5894
