Forums >> Revit Building >> Technical Support >> Visiblility Problems
Mon, Mar 13, 2006 at 2:31:05 PM | Visiblility Problems
joelminns
Having a minor problem that i hope will be an easy fix. I have several Trees and shrubs in my model. Some of them are showing up in my floor plan, and some of them in my site plan. I would like all of them to show up in my site plan and i cant seem to do it with the visibility settings. Thanks
Mon, Mar 13, 2006 at 5:10:42 PM | RE: Visiblility Problems
eldados
eldados Avatar
4.5 Stars: 8 Votes
is it a steep site? if it is, the only way is to play with the cut plane. if it's not, make sure your category is showing in your plan...
Integrator
KarelCAD
Hiding Detail Tags in other views
Sun, Sep 6, 2009 at 1:09:41 PM
Installation Problems
Workflow & Implementation >> Chameleon
Mon, Jan 14, 2013 at 12:07:30 PM
Beam Problems
Fri, Sep 7, 2007 at 7:26:32 AM
Revit Print Problems - UPDATE
Fri, Sep 2, 2016 at 1:44:13 PM
Any known problems converting projects to 2009 form 2008?
Thu, Aug 21, 2008 at 5:49:13 PM
Page generation time: 0.3349
