Forums >> Revit Building >> Tips & Tricks >> Need Custom railing with vertical weave help
Tue, Dec 9, 2014 at 2:37:39 AM | Need Custom railing with vertical weave help
ivanzep
How would you approach modeling this railing? The tricky part (for me) would be the weave in between the balusters, that is supposed to be a single cable filling each panel. It would be best if it were parametric so we could look at different configurations quickly. I.e. Weave separation, baluster height etc.Edited on: Tue, Dec 9, 2014 at 2:38:52 AMEdited on: Tue, Dec 9, 2014 at 2:39:10 AM
Edited on: Tue, Dec 9, 2014 at 2:40:35 AM
Tue, Dec 9, 2014 at 2:40:07 AM | Need Custom railing with vertical weave help
ivanzep
Image 2
Tue, Dec 9, 2014 at 11:35:08 AM | Need Custom railing with vertical weave help
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Start with the Baluster template. You can use model lines to represent the wire. Create a few family types with different spacing, so you can swap them in the project.
Tue, Dec 9, 2014 at 12:13:10 PM | Need Custom railing with vertical weave help
Can you find that maybe in a material?
That's what I used for these Mesh panels.
CUSTOM RAILING
Tue, Dec 13, 2011 at 1:17:22 PM
help...Wood plank railing gaps
Wed, Aug 17, 2011 at 10:12:05 PM
Custom Railing
Mon, Nov 20, 2006 at 10:31:30 PM
Basket Weave Heringbone Hybrid Pattern HELP!
Thu, Apr 5, 2018 at 1:07:30 AM
RAC2008- How to import railing from one file to another
Wed, Aug 1, 2007 at 11:23:34 AM
Page generation time: 0.1594
