Forums >> Community >> Newbies >> Help?
Mon, Dec 8, 2014 at 4:07:15 AM | Help?
22xx
Hello, I just installed my revit 2015, but i have a problem, upon installing, i cant find any families, template and everything, is this possible? i mean how will i fix it? and then, if i downloaded every files that i need, example templates, is it okay if i just put them in one folder together with the things that i need, like plumbing fixtures, hvac and etc? TIA!
Tue, Dec 9, 2014 at 12:58:18 PM | Help?
You needed to install the content library.   Maybe you did and just don't know where they are located because of how you customized the install.   Look for them first, then if that fails, re-install and pay attention to all of the options.
Tue, Dec 9, 2014 at 3:24:30 PM | Help?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yup you need to reinstall and click configuration and select what you want to install and where it's going. If it's a business you may want to install the content to a network drive and point everyone there, otherwise just go with the default location on the c:\ drive.
Page generation time: 1.1897
