Forums >> Revit Building >> Technical Support >> Type Catalog
Mon, Mar 13, 2006 at 1:58:57 PM | Type Catalog
sjmintz
I am creating the text file for my type catalog and have had no problems filling in the parameters. When a family has 2 or more types, is there a way to list in the catalog which type it should use. For example: I have a family for web penetrations in Wide Flange beams. There are the usual beam parameters which are listed in the type catalog. Additionally, in the family I have two types: SQ (for square openings, H_opening = W_opening) and RECT (for rectangule openings, H_opening independent of W_opening). I'd like to be able to select the beam size (i.e. W12x50) along with the opening type (SQ or RECT). Based on the help file section "Creating a Type Catalog" it would seem like I could have two entries: W12x50 SQ W12x50 RECT How do I relate an entry in the type catalog to a specific type in the family?
adding parameters to a family with a type catalog
Thu, Feb 19, 2009 at 11:10:20 AM
Revit 2010 Yes/No in type catalog
Mon, Mar 29, 2010 at 9:14:02 AM
type catalog
Fri, Apr 8, 2005 at 2:35:30 PM
Family Type Catalog - Model Parameter will not take
Tue, Sep 1, 2009 at 8:01:06 AM
Uploading type catalog file directories with RFA files
Fri, May 14, 2004 at 12:49:21 AM
Page generation time: 3.3483
