Forums >> Revit Building >> Technical Support >> Black background in text box
Thu, Dec 4, 2014 at 4:35:10 PM | Black background in text box
Amanda840
We are using Revit 2015.
Unwanted black background appearing in text boxes.
A co-worker is working in a file called Foundations.  When he links in another file called Roof, the text within the Foundations file turns from regular black to black on a black background.  All types of text change, its not just one particular text type.  The Roof file itself when opened on its own does not show this issue.  When the Roof file is unloaded and removed from the Foundations file, the text issue remains.  He then closes without saving and re-opens the Foundations file and there is no text problem.  It comes back when he re-links the Roof file.  No other file when linked causes the text to change.
Has anyone encountered this before?  What was the fix?
Thanks!
Fri, Dec 5, 2014 at 10:50:50 AM | Black background in text box
It sounds like some sort of corruption.   Send the file to Autodesk.
Thu, Feb 18, 2016 at 8:34:29 AM | Black background in text box
rozicki
5 Stars: 2 Votes
Restart computer worked for me.   It doesn't seem to be Revit related, other users on the same file don't have this issue.
Edited on: Thu, Feb 18, 2016 at 9:04:49 AM
Fri, Feb 19, 2016 at 7:23:02 AM | Black background in text box
mansell5
3.5 Stars: 4 Votes
we had that as well. its a text mask.
from memory it occurred when printing to pdf. we use cutepdf.
we were experimenting with a black background on revit drawing screen instead of white.
text edit box background
Thu, Feb 26, 2009 at 8:59:12 AM
Black background on text (imported DWG)
Thu, Feb 18, 2016 at 8:38:47 AM
revit 2012 - display option background disappeared and turned black
Mon, Jun 25, 2012 at 4:48:13 PM
Decal Background is Black
Wed, May 1, 2019 at 5:57:17 AM
White text on Black background
Thu, Aug 9, 2007 at 3:05:05 PM
Page generation time: 0.8642
