Forums >> Revit Building >> Technical Support >> Families - Locking complex geometry
Thu, Dec 4, 2014 at 9:58:27 AM | Families - Locking complex geometry
AVig
Is there a way to lock a complex element to a reference plane within a family? Example, locking a complex faucet to a reference plane that changes the height of the countertop? I've tried grouping the model elements but it won't allow me to lock them in any way.
Thu, Dec 4, 2014 at 10:06:03 AM | Families - Locking complex geometry
If the faucet family is a face based family, and it is inserted on the face of a counter, it will move with the counter.
Thu, Dec 4, 2014 at 10:41:44 AM | Families - Locking complex geometry
AVig
It is not a faced based family, it is the standard "plumbing fixture" template. If there is an easy way to change it to a face based family, I'm all ears.  A work around that works is saving the faucet as a separate family and inserting into the main family and locking it to a reference plane. Seems like an extra step that is not needed.
Thu, Dec 4, 2014 at 10:48:22 AM | Families - Locking complex geometry
You are nesting a non-hosted plumbing family into another family.   Is that correct?
Then simply dimension where that family is in the host family from a host family element or reference plane and lock that dimension.   Your done.
Complex Family Editing
Mon, Mar 9, 2015 at 1:01:45 PM
Scheduling Coordinate Points for Complex Geometry
Fri, Jan 21, 2011 at 10:46:22 AM
Creating Complex geometry
Wed, Nov 16, 2005 at 2:59:35 AM
3D Max to Revit for complex geometry?
Thu, Mar 17, 2011 at 3:05:43 PM
Imported Complex Geometry -->wall by face
Fri, Sep 7, 2007 at 12:27:38 PM
Page generation time: 1.7647
