Forums >> Revit Building >> Technical Support >> Sloping 5/14" metal deck roof to sit on sloping OWSJ structure
Wed, Dec 3, 2014 at 8:42:41 AM | Sloping 5/14" metal deck roof to sit on sloping OWSJ structure
Weezer23
I'm using revit 2015 and wanted to create a roof that slopes with the structure below. So there's one level at the front of the building and another level at the rear. I want to slope a roof to match the sloping structure below from one level to the other. Why is this so hard?
Any advice would be great, thanks!
Wed, Dec 3, 2014 at 8:50:16 AM | Sloping 5/14" metal deck roof to sit on sloping OWSJ structure
It is not hard but we can't give you much advice since we don't know anything about the roof.
Read your HELP: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-B5B5E96D-40F2-4CA1-8B09-C05740634C97
Pay attention to slope arrows - that may be the solution you need.
slope metal roof deck
Thu, Jul 21, 2011 at 9:40:39 AM
sloping steel roof deck problem
Wed, Mar 5, 2008 at 5:55:12 PM
SLOPING ROOF WINDOW
Wed, Aug 16, 2006 at 6:01:35 AM
Warping Deck/Sloping Joists
Wed, Aug 25, 2010 at 6:45:18 PM
Taper Insulation sloping flat roofs
Wed, Nov 28, 2007 at 5:22:09 PM
Page generation time: 1.0935
