Forums >> Community >> Newbies >> CAD/Revit Detail
Tue, Dec 2, 2014 at 12:31:38 PM | CAD/Revit Detail
cdhackett
Hello,
I am in the need of a AutoCad detail from Article 501.15 of the NEC 2014 Handbook. Specifically I am needing a detail for the Exhibit 501.8 A Class I Division 1 location where threaded metal conduits, seal fittings, explosionproff fittings, and equipment for power and lighting are used. I was wondering if anyone had this detail already that they could share. I would then be able to import into Revit as needed as well. Hope someone can help me out. Thanks in advance.
Mon, Jul 6, 2015 at 2:40:41 PM | CAD/Revit Detail
marscreature
4.5 Stars: 3 Votes
A work around to this would be to download the PDF from https://archive.org/details/nfpa.nec.2014
Then use the "Snipping Tool" built into Windows computers, or some other screen capture method, and link the image of Article 501.15 into your Revit Project.
Detail Library
Mon, Oct 19, 2015 at 10:13:09 AM
Floating Windows 4 Multiple Monitors & wow putting CAD into sweeps is work.
Fri, Jul 14, 2006 at 4:58:12 PM
Trouble with Creating a Standard Detail [ 1 2 ]
Fri, Dec 20, 2013 at 6:49:09 AM
15
imported cad detail
Fri, Mar 30, 2007 at 7:44:43 AM
CAD import resolution
Fri, Aug 1, 2008 at 11:22:45 AM
Page generation time: 1.8352
