Forums >> Community >> The Studio >> Visibility Problems
Mon, Mar 13, 2006 at 3:44:17 AM | Visibility Problems
joelminns
I have a question that im sure will be easy to answer. Im a beginner and i am a little confused. Let me explain. I have tennis courts and basketball courts. Both are of the same family - "Generic Models". I need the Tennis courts to show up in the site plan, and the basketball courts to show up in the floor plan. As of now, they are both showing up in the floor plan. My uneducated question is... How do i get the tennis courts to show up in the site plan. Can i change the family type of the tennis courts (or any model for that matter)? PS. I have tried messing with the visibility settings and neither of them show up under the generic models category. Thanks, Joel Post edited on 2006-03-13 03:48:55 Post edited on 2006-03-13 03:57:54 Post edited on 2006-03-13 04:15:41 Post edited on 2006-03-13 04:16:23
Mon, Mar 13, 2006 at 9:24:39 AM | RE: Visibility Problems
FlyinHigh
1 Stars: 1 Votes
you may be able to save them again on your pc and change the family type so that they are different, then you should be able to change the visibility.
Mon, Mar 13, 2006 at 1:53:19 PM | RE: Visibility Problems
joelminns
How would i go about changing the family type after ive saved them again?
Mon, Mar 13, 2006 at 5:15:59 PM | RE: Visibility Problems
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. I think family catagory could be your answer. Try this, In the 'family editor' go to > Settings > Family Catagory and Parameters. (Have you seen this before?) You can change the family catagory and then use the visibility controls once you place the family in a model. Iie: Make the Tennis court a Site Catagory. In other words you could actually tell a window family that it is in a door catagory and it would turn off if you turned off door visibility. dg http://www.dgcad.com
Mon, Mar 13, 2006 at 7:31:55 PM | RE: Visibility Problems
joelminns
I knew there had to be an option like that somewhere. Thanks a lot
VISIBILITY PROBLEMS
Wed, May 2, 2007 at 3:31:32 AM
visibility graphics problems-please help!
Sat, May 28, 2011 at 4:33:53 PM
Visibility Problems
Sat, Jun 13, 2009 at 2:17:06 AM
VG problems with uploaded beam family
Tue, Aug 28, 2007 at 6:49:43 PM
HELP!!! Problems with Room Tag
Tue, Dec 3, 2013 at 7:17:38 AM
Page generation time: 0.2384
