Forums >> Revit Building >> Technical Support >> Additional Lines in Perspective
Tue, Dec 2, 2014 at 9:18:46 AM | Additional Lines in Perspective
benlink
Using Revit 2015, I'm making a pdf of a perspective view (see attached) and get some additional lines around the eleptical, large, ceiling based family.  It doesn't have anything to do with the connection to the ceiling, as I've separated the family from the ceiling, but in every perspective it adds the additional spiral lines.  I've made the perspective with the family hidden and the lines aren't there.  In short, the problem is in the family.  I tried to make it as an in-place family with the same results.  I adjusted the perspective and pulled new views, all with the same results.
Finally, I have another file, using the same family but smaller, in which I've modeled another scheme in the same space, and I don't have the problem.
Any suggestions?
Edit: I realize it wasn't clear - the lines only show up when I make a pdf.  They're not there in model.
Edit 2:  I changed the size of the family to 95% of it's original size (99% & 96% didn't work).  This seemed to appease the beast.  Though, it still measures smaller than what we need.  I have this work around for now, but would still like to hear anyone's thoughts and ideas regarding the initial problem.
Kind regards,
Ben
Edited on: Wed, Dec 3, 2014 at 9:17:28 AM
Edited on: Thu, Dec 4, 2014 at 12:17:55 PM
Floor lines showing through siding in perspective...
Tue, Apr 15, 2008 at 5:05:10 PM
12
Perspective Problem
Fri, Jun 26, 2009 at 12:13:43 PM
Lines too heavy in perspective view
Wed, May 1, 2013 at 6:36:38 PM
PERSPECTIVE LINES
Thu, Mar 2, 2006 at 5:19:50 PM
Line styles won't appear in Perspective view
Tue, Sep 8, 2009 at 3:47:39 PM
Page generation time: 5.2292
