21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Perspective view image printing to PDF problem
I have imported an image of the sky (jpg) into perspective view. When I try to print to PDF it strips the image of the sky. Iwas able to export the view as an image - it worked, but I need to place it on the sheet and print to PDF. is there any solution to it?
images attached - you can see one is a pdf image printed and lost the sky. Thanks in advance.
Re-import the image and place that on your sheet.
I have and I have tried attaching different image - same result. I was able to export as an image to jpg though. it really puzzles me.
It sounds like your PDF writing driver may not process this correctly. Try something else - we use cutepdf.
I did not mean to re-import the background. I meant for you to import the finished image an place that on your sheet.
Printing PDF Line Drawing - Wont show surface textures |
Tue, Oct 23, 2012 at 9:24:39 AM
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
problem printing line weight to pdf |
Tue, Sep 30, 2014 at 3:31:49 PM
PDF Printing Error |
Tue, May 11, 2010 at 2:20:03 AM
Printing with Shadows on and PDF |
Wed, Jun 3, 2009 at 1:54:17 PM
