Forums >> Revit Structure >> Technical Support >> Annoying line in joined gable roof
Sun, Nov 30, 2014 at 4:06:00 AM | Annoying line in joined gable roof
AnaBia
Hello,
Please see pics attached. I can't get the highlighted line to dissapear. I think it has something to do with the slope, however both the existing roof and new gable extension have a slope of 30 degrees. I also tried reducing and inceasing the width of the new gable with no luck.
Cheers
Ana
Mon, Dec 1, 2014 at 8:04:02 AM | Annoying line in joined gable roof
If you joined the roofs and the line didn't go away then either the angles or the height is not the same.  Be careful - 30 degrees may not be the same as 30.001 .... If it is fixed at 30 on both then you should be ok.  Cut a section and LOOK!
How to join 2 gable roof?
Mon, Sep 28, 2009 at 9:16:37 PM
Extending one gable roof into another
Wed, Jun 11, 2008 at 3:09:42 PM
Roof
Fri, Dec 30, 2005 at 8:11:33 AM
Extending roof into double gable
Fri, Oct 23, 2015 at 10:39:59 PM
"Dutch Gable" roof
Mon, Mar 31, 2008 at 1:35:54 PM
Page generation time: 3.0783
