Forums >> Revit Building >> Technical Support >> Modifying revit element in annotation
Fri, Nov 28, 2014 at 8:24:22 AM | Modifying revit element in annotation
Profiil
Hello
I've got question about modifying elements in annotation. As it is too difficult to do the modifications on all elements then it is profitable to show how its done on one element. So 2d is a must
Now the problem.
I am able to cut the profile of a wall smaller but how am I able to grow some "meat" on it. Adding a hatch disturbs the wall weights and does not look nice. So is there a way to make element bigger in 2d mode.
For example if I'd have a wall section and I would like to add a corbel to it (I can do it by using sweep but just for example).
Fri, Nov 28, 2014 at 9:33:27 AM | Modifying revit element in annotation
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
See picture. Should be self-explanatory.
Annotation fill colors.
Wed, Oct 5, 2005 at 6:23:11 PM
Revision Numbering
Wed, Jun 17, 2015 at 12:39:24 PM
Annotation Object Styles [ 1 2 ]
Thu, Dec 17, 2009 at 11:56:38 PM
15
sloped annotation symbol text
Mon, Aug 15, 2011 at 8:04:20 PM
Annotation Crop boundary is not visible
Mon, Sep 24, 2012 at 3:16:13 PM
Page generation time: 1.4385
