Forums >> General Discussion >> Revit Project Management >> Backup Central File
Fri, Nov 28, 2014 at 1:41:55 AM | Backup Central File
DoubleW
Our firm has a large project that's already under constuction.
All of a sudden the client has requested that two floor fitouts be swapped over - the First Floor moves to the Second and vice versa.
I'd like to backup our central file before proceeding, in case it all goes pear-shaped.
How does on go about backing up a Central File and making sure that the Local Files are updating the new Central File and not the backed-up one?
Thanks!
Edited on: Fri, Nov 28, 2014 at 1:55:05 AM
Learn Things Blisteringly Fast (Don't be Fooled by the Title):
http://www.amazon.com/dp/030746363X/?tag=wbww-20
Mon, Dec 1, 2014 at 7:21:11 AM | Backup Central File
Just do a save as .... and in that process, check "make this file a central file".   Now make sure you close that file and open your old one.  Everyone is stll connected to the old file.
Mon, Dec 1, 2014 at 7:37:26 PM | Backup Central File
DoubleW
Thanks WWHub.
CENTRAL FILE back-up Files
Tue, Jan 29, 2013 at 1:26:27 PM
Restoring from a backup file when filesharing
Thu, Jun 3, 2010 at 12:34:36 PM
Audit central file - it's giving error
Mon, Nov 30, 2015 at 9:43:50 AM
Recovering a file from Backup Files W/O/ the original File
Fri, Feb 6, 2015 at 9:40:43 AM
Central File & its Arch link - disappeared!
Mon, Aug 29, 2011 at 2:54:22 PM
Page generation time: 4.9416
