Forums >> Revit Building >> Technical Support >> loss of cut pattern
Thu, Nov 27, 2014 at 7:53:07 AM | loss of cut pattern
integrity
I have created a two story masony wall and get the correct cut pattern on the first floor view. However, I get no cut pattern on the second floor view even though my top is set to 8' and the cut is 5'. What's up?
Thu, Nov 27, 2014 at 10:35:04 AM | loss of cut pattern
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Integrity,
Are the view details the same detail? At the bottom of the screen, next to the scale there are two buttons. Make sure its "fine" or "Medium".
if thats not the issue can you upload some images?
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Fri, Nov 28, 2014 at 8:47:10 AM | loss of cut pattern
integrity
Well that was stupidly simple. Thanks!
cut pattern issue
Wed, Jan 28, 2015 at 3:53:15 PM
Stiar cut pattern or fill pattern.
Sun, Feb 19, 2006 at 11:46:36 PM
Showing column cut on top of wall cut pattern
Tue, May 28, 2013 at 4:06:05 AM
Heat loss calculation formula
Wed, Apr 29, 2009 at 10:09:09 AM
duct static pressure loss
Mon, Aug 15, 2011 at 2:18:11 PM
Page generation time: 1.0858
