27 Users Online (25 Members):
Forums >> Revit Building >> Tips & Tricks >> Measure the length of multiple lines at once
0 Posts No Rating |
Hi everyone.
I just finished drawing a ton of floorheating. Is there no way of marking a lot of lines, and then get the combined length?
I tried Googling it, but all the other sugestions seems a little wierd to be honest. There must be simpler ways.
Thanks in advance.
Kind regards,
Sebastian
0 Posts No Rating |
Just noticed the sticky about posting in Tips and Tricks. If anyone can move it to Technical that'd be appreciated. Thanks.
0 Posts No Rating |
Nobody?
There are some ways to accomplish that (line based family or railing to name a few). This is just one of them: http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-Customize/files/GUID-DEADF731-AD3F-47F8-B2C8-B31341CA0C5F-htm.html (Two-Pick Family to Calculate Fire Exiting Distance).
Google for ‘fire exit path’ or ‘exit travel distance’, the solution will also apply to your issue.
3 Posts No Rating |
Measure along an element. only works for a chain of model lines
use the tape measure tool and make sure the "chain" check box is checked and you can measure multiple lines along a path.
Measure tool running units |
Mon, Jan 23, 2017 at 7:21:11 AM
Total length of reference lines or extrusion in a family |
Tue, Oct 15, 2013 at 7:41:24 AM
Measurement of detail lines |
Tue, Sep 2, 2008 at 2:46:13 PM
Topo contours |
Wed, May 9, 2012 at 8:19:10 AM
Tag Text Length |
Fri, Jul 4, 2008 at 10:46:56 PM
