25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Automatic Beam System and Tag On Options
Someone has asked the same question previoulsy, but did not get the answer, obviously it is not just my problem. I am following a book on Revit 2014. After selecting the "Beam System" button the next 3 buttons supossed to appear - "Automatic Beam System"; "Sketch Beam System"; "Tag On Placement". They do show up only for a split second and then jump to a next stage. How to get them to show properly so, i could actually select tag on placement button? Please?
The space needs to be enclosed with structural walls, otherwise auto. beam system is not available.
Thank you PijPiwo! I have used architectural walls instead of structural - that is where culprit is! btw I want to "pit piwo" too.
Bottoms up then!
Cheers
Beam System Tag |
Fri, Aug 14, 2009 at 3:09:33 AM
Adding a beam system issue |
Sun, Jun 15, 2014 at 2:58:10 PM
How to tag a structural beam system? |
Mon, Feb 11, 2013 at 4:04:43 PM
sloping structural beam system - having difficulty in drawing |
Thu, Dec 30, 2021 at 10:33:02 AM
Tag Beam System In section/elevation |
Wed, Jul 5, 2006 at 3:56:43 PM
