Forums >> Revit Building >> Technical Support >> Copying text & dims from one file to another in 2012
Sun, Nov 23, 2014 at 11:12:56 PM | Copying text & dims from one file to another in 2012
Pele
Pele Avatar
I inadvertantly started working on the wrong file to pick up on a project that has been on hold for 3 months. So I have a new file that I want to keep but there are floor layouts with the same model geometry but with text & dimensions that I need to carry on in the new file. How do I grab all the text or dimensions from a file & paste it into another. Is it just copy & paste, ctrl c to ctrl v ??
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Mon, Nov 24, 2014 at 8:10:38 AM | Copying text & dims from one file to another in 2012
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
 "Is it just copy & paste, ctrl c to ctrl v ??" Did you try this? What happens when you do?  If everthing is the same the dimensions will copy without a problem, it there is a difference you can't copy the dimension.  The text is just annotation so that will copy wherever you want it.
Mon, Nov 24, 2014 at 8:13:54 AM | Copying text & dims from one file to another in 2012
If the files are not the same model elements then dimensions and tags will not copy/paste.   All other annotative elements will.
Tue, Nov 25, 2014 at 5:22:34 PM | Copying text & dims from one file to another in 2012
Pele
Pele Avatar
Thanks.
Yes I was able to copy paste the text, but for some reason it came through rotated 90deg out. The two models are the same rotation. I was able to copy the dimensions as well, a few did not copy (only 3 out of 50).
Cheers Dermot
www.dmbd.net
exporting point info from revit structure into a text file
Tue, Jul 24, 2012 at 12:20:44 PM
Revit 2012 Sheets & Model Space / Paper space in CAD
Wed, Jun 12, 2013 at 6:36:59 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Can there be two types of dimesions...
Thu, May 3, 2007 at 11:23:37 AM
Worksets: Copying from one drawing to another?
Tue, Jan 5, 2010 at 4:53:39 PM
Page generation time: 0.7563
