Forums >> Revit Systems >> Tips & Tricks >> 22" Exhaust Subduct
Wed, Nov 19, 2014 at 4:02:56 PM | 22" Exhaust Subduct
MagicJS
MagicJS Avatar
Anyone have a good way or family to model the 22" subduct exception for fire and smoke dampers? I want the subduct attached to the riser, but still showing the geometry inside the main shaft.
Any ideas like creating custom Tees, accessory etc.
Fri, May 25, 2018 at 10:17:49 AM | 22" Exhaust Subduct
travispremo
I realize this is 4 years after your post, but I'd hate to see this go unanswered. I had the same question. Off the top of my head, I am considering modifying a takeoff family. Basically model the subduct beyond the tap into the shaft, then you're left with a takeoff outside the shaft to which you can connect duct work that empties into the shaft. You would need a round version and a rectangular version. I'm going to model it and see how it goes.
Help with Revit MEP
Thu, Sep 10, 2009 at 10:48:22 AM
Hide all objects of same family
Wed, May 23, 2012 at 1:47:54 AM
create new connector system type
Fri, Sep 18, 2009 at 3:11:38 PM
duct system types
Wed, Dec 2, 2009 at 10:08:53 AM
Creating a Duct Accessory with both Supply AND Exhaust Connectors... how?
Wed, Aug 2, 2017 at 8:56:48 AM
Page generation time: 1.2465
