11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> View Reference center point is too far from the label.
1 Posts No Rating |
Does anyone know how to fix the View Reference family so the center drag point is closer to the actual label text? The problem is that in larger scale views, the center drag point is getting cropped by the annotation crop boundry and therefore does not display.
I have tried rebuilding the View Reference and moving the label and/or the center reference planes in the family, but it still displaces the center drag point once it is made into a View Reference and loaded into the project
I have tried researching an answer to this but have only found this thread on Autodesk:
http://forums.autodesk.com/t5/revit-mep/view-reference-annotation-drag-mark/td-p/4771397
It does not solve the issue.
1 Posts No Rating |
Sorry, I am in Revit 2015
Share your family so we can see your problem.
I don't think I have the same problem.
Center Reference Planes....... |
Tue, Jan 30, 2018 at 9:48:46 AM
Revit 2009: Custom label in title view & Reference sheet |
Mon, Dec 8, 2008 at 7:09:23 PM
Reference Point Hosting Problem |
Fri, Jan 31, 2014 at 4:53:38 PM
orthogonal dimensions to radial dimension center point |
Fri, May 14, 2010 at 3:22:32 PM
How do you center a cased opening in a wall? |
Wed, Jan 12, 2011 at 1:49:38 PM
