Forums >> Revit Structure >> Technical Support >> revit families and picking points
Tue, Nov 18, 2014 at 2:37:39 PM | revit families and picking points
gregroberson
gregroberson Avatar
Is there a way to make a revit family that reads the input from my mouse.  For example, addind a detail item that is only a line with four segment.  I want to pick the points with my mouse and have the lines, or walls, or whatever grouped curse a family.
I hope am clear to what I am inquiring.  please let know if I am off base or if there is no need at all.
greg
Tue, Nov 18, 2014 at 2:50:43 PM | revit families and picking points
Line based family ....
Tue, Nov 18, 2014 at 3:03:25 PM | revit families and picking points
gregroberson
gregroberson Avatar
WWHUB, that is where I started, but I want to thave multiple lines at differenct angles and such.  I am trying to get them strung together so after I can pick a vertex on two segments and move it around after it is placed.  Any more thoughts or ideas?  perhaps I am not understanding how to get multiple segments by mouse clicks
Tue, Nov 18, 2014 at 3:11:09 PM | revit families and picking points
You can pre-establish multiple segments ("...only a line with four segment...") just a beginning and end pick- but not by independent mouse clips for each segment.
Create topography from instance not picking up points
Wed, Jan 30, 2013 at 9:51:10 AM
How can you place a component's width by picking two points?
Thu, Dec 22, 2005 at 3:42:01 AM
picking points from the 0,0,0 p.
Thu, Jan 22, 2015 at 10:01:40 AM
Site Plan - Topo
Thu, Feb 13, 2014 at 5:50:25 AM
Exporting topography points from Revit to AutoCad
Sat, May 23, 2015 at 11:21:41 AM
Page generation time: 2.3192
