Forums >> Revit Structure >> Technical Support >> TAGS Need to stay Anchored!
Tue, Nov 18, 2014 at 10:16:57 AM | TAGS Need to stay Anchored!
CreekFreak
When you model a floor or structural slab etc. then tag it, the tag nicely centers itself about the slab. Nice gesture, but only useful when the tag is dropped the first time.
If I move a tag into different position to suit other annotations and graphic quality in that view, this relocated position is where I want the tag to stay for the duration of the project regardless of whether or not I change the slab geometry. (When slab geometry is changed the tag re-centers itself to the new geometry).
Is there something within the tag family that can be disabled so that tags don’t move when I edit the slab? Changing the geometry of the slab is likely going to happen many times in the duration of many projects. This revit-ism of relocating the slab tag for me every time I update a slab shape is counterproductive to getting the actual drawing views complete. If my slab tag shows up in multiple views I don’t want to have to predict how many of my views this slab tag has moved in.
Pinning them does not stop this behavior.
Tue, Nov 18, 2014 at 12:28:16 PM | TAGS Need to stay Anchored!
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I don't believe theres a way to do what you want. I do suggest that you don't tag things until they are a little more perminant. This goes for rooms, doors, windows etc as well.
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Room Tags Filtered?
Tue, Aug 15, 2006 at 6:21:29 PM
Room Tags and Crop Regions
Wed, Sep 28, 2005 at 10:41:25 AM
View Title Anchored at the Right Side
Wed, Jan 31, 2024 at 2:27:23 AM
Interior Lighting - lights stay dark when rendered
Sun, Oct 25, 2015 at 4:27:52 AM
Page generation time: 1.6067
