14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> Column base plate tag units display.
I am in the process of creating tags for use with the graphical column schedule.
I have added a base plate to my column familys, with shared parameters. The parameters ask for dimensions to define the base plate.
The column tag I am creating pulls the base plate dimensions.... the only issue I am having with this is the base plate dimensions reporting in feet and inches. Is there any way I could change them to report only in inches? ex... 1'4" = 16"
I attached some screenshots to clarify. let me know if I need to post more information.
I have only been working with revit for a few months so let me know if my terminology is off...
Any help is appreciated.
If I understand your question correctly, in the tag family, select your dimension label and follow the picture.
Edited on: Fri, Nov 14, 2014 at 6:10:30 PM
I feel like a bum now....it was that easy.
Thank you!
Edited on: Mon, Nov 17, 2014 at 2:29:07 PM
base plate visibility problem |
Thu, Dec 1, 2011 at 12:34:33 PM
COLUMN BASE ELEVATION - TAG |
Tue, Dec 2, 2014 at 1:25:37 PM
Attaching a footing to a column with a base plate nested into the footing family |
Thu, Jul 11, 2019 at 12:23:42 PM
Column Base Plate Nested Family - GCS Visibility |
Sat, Feb 21, 2009 at 9:17:59 AM
Base Plates & Graphical Column Schedules |
Mon, Feb 22, 2010 at 11:51:01 AM
