Forums >> Revit Building >> Technical Support >> COPY SECTION VIEWS BETWEEN PROJECTS
Wed, Nov 12, 2014 at 2:55:10 PM | COPY SECTION VIEWS BETWEEN PROJECTS
jamiekgoettl
HOW DO I COPY SECTION VIEWS FROM ONE PROJECT TO ANOTHER? PLEAE HELP!
Wed, Nov 12, 2014 at 3:35:00 PM | COPY SECTION VIEWS BETWEEN PROJECTS
Model section views - no way.... They are model driven!  ((( If you must - you can export to CAD and re-import as dumb linework in your other file.... A very BAD process that I would never recommend))
Hopefully you have learned to really let your sections be model sections and not drafted over.   Typically the model elements will work with only minor modifications like edit cut profile and maybe repeating detail elements like brick and block.
Detail views are different - obviously you add more detail elements here.   In these cases, you might try copying the detail elements to clipboard and pasting them in the other file's view.
exporing detail view, drafting views, + legend views to other revit projects 9.1
Thu, May 3, 2007 at 4:33:32 PM
Coping Views between Revit projects. is it possible?
Sun, May 26, 2013 at 1:42:59 PM
Copying section cut
Tue, May 26, 2015 at 11:34:45 AM
Linked Cad & Views across projects
Thu, Oct 25, 2007 at 10:54:18 AM
Drafting a wall section
Thu, Dec 26, 2013 at 9:54:41 AM
13
Page generation time: 1.6479
