18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Room tag
0 Posts No Rating |
Hallo, i have problem with room tags in floor plan 2 plan its ok, but i want tag 1. floor plan write error to me : None of the created elements are visible in Floor Plan: 1.NP_skutkovy stav View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.In schedule i see this rooms... :/ but i need tag on floor plan.Ty for help.
Look in VG / Annotations - Turn on room tags.
0 Posts No Rating |
i have turn on room tags in visibility settings... but nothing :/
Possibly I don't understand your question but I don't think so. You got an error message which means to me that the room is there and on.
To tag a room in a view, the rooms must be on, the room tag category must be on. If you can pick the room, then you can tag it. If you can't pick the room, then the room is not on or it is not cut by the view cut plane. You can't tag a room above or below the view cut plane.
0 Posts No Rating |
Is the workset correct?
Room tag not showing in only one room. [ 1 2 ] |
Sat, Sep 27, 2025 at 3:40:00 AM
15
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
Room Tag Leaders |
Thu, Oct 21, 2021 at 9:45:56 AM
ROOM TAG TAGS ONLY HALF OF THE ROOM |
Wed, May 6, 2015 at 8:58:21 AM
