Forums >> Revit Building >> Technical Support >> Export all properties BYLAYER, and create new layers for overrides.
Tue, Nov 11, 2014 at 11:53:51 AM | Export all properties BYLAYER, and create new layers for overrides.
cbeauregard
Ive been working on a export setup from Revit to DWG to match my companies CAD standards. This is not easy, but im making slow progress. I wanted more control over layers so I decided to export all properties BYLAYER, and create new layers for ovverides. I like this because I can change the outline color of a column without messing with the hatch. (for example it names Concrete-elevation, concrete-elevation 1, etc..). I dont want to haveto change these colors and line weights in CAD everytime. How can I modify the newly created layes that the export creates before its actully exported? Is this possible?
Thanks
Fri, Nov 14, 2014 at 12:22:28 PM | Export all properties BYLAYER, and create new layers for overrides.
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I believe it's all there in the Export > Options (very bottom) under the application pull down.
Export to DWG creating color overrides in text families
Tue, Feb 10, 2015 at 8:27:00 AM
Layers mapping for DWG export
Thu, Jun 18, 2015 at 11:55:54 PM
Grid line problem (cad export)
Wed, Apr 11, 2012 at 7:18:20 AM
renaming the export settings
Fri, May 7, 2010 at 8:51:02 AM
Turning off Layers when Exporting to Cad
Wed, Nov 5, 2008 at 6:06:36 PM
Page generation time: 2.8243
