11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Pattern Issues
3 Posts No Rating |
hi...
Does Anyone know how i can align a pattern in a curved wall???
I am having trouble with that. The "align" command does not work in a curved wall...
Any suggestion????
Already checked everywere...but no help on this issue...
Can you please help me???
Its kind of urgent!!!
Thank you!!!
Post edited on 2006-03-12 20:52:50
are you putting your mouse over and "tabbing"?
3 Posts No Rating |
well, i tryed everything but i cant do anything...
it just doesnt select anything....i needed to print in the shaded view but so the pattern would be visible
I ll try to upload a view
3 Posts No Rating |
does anyone knows how to slove this problem?
No problems achieving what you're after here...
NOTE: The align tool will not work to align the patterns. In elevation, tab select a pattern line then drag and align it "by eye". As Eldad eluded.
HTH.
Eureka ! you can move the vertical lines of a pattern, on a curved wall, by rotating it in plan view using the center of the wall (of course)
surface pattern visibility issues |
Thu, Jan 5, 2006 at 3:13:47 PM
Issues creating simple Fill Pattern |
Fri, Jan 3, 2020 at 3:47:48 AM
Model Pattern Problems |
Thu, Jan 18, 2007 at 10:36:47 PM
Floor pattern not showing up when the pattern is model pattern |
Fri, Nov 3, 2023 at 9:11:59 PM
create a custom fill pattern [ 1 2 ] |
Mon, Jun 28, 2021 at 2:32:51 PM
29
