19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Family editing help!
0 Posts No Rating |
Hi. I have recently started learning and working on Revit.
I am stuck and need help! I am attaching a family file for Concrete beam which has 48mm size grooves on both sides. I want to change the size of the groove from 48mm to 50mm (keeping the beam size same as 400mm). Can anyone explain how can I do this? I think this might have been done using sweep command or something but not sure. An earliest reply would be appreciated.
Thanks
Anubhav
yes it is a solid sweep with profile
what you need to do is to look for the profile in the project browser (under FAMILIES> PROFILES) and right click EDIT.
it will open the profile in another window for you to change 48 to 50
0 Posts No Rating |
Thanks! it worked!
Help editing All in one Revit Content families |
Mon, Dec 21, 2015 at 1:27:25 PM
HELP WITH EDITING FAMILY |
Mon, Oct 22, 2018 at 8:05:02 AM
Problem editing a family |
Wed, Dec 29, 2010 at 10:20:34 AM
Trouble editing an existing family Window |
Wed, Nov 23, 2011 at 2:40:38 AM
Editing a family created by a company |
Fri, Feb 14, 2014 at 9:23:18 AM
