Forums >> Revit Building >> Technical Support >> DWG visibility in linked files
Mon, Nov 10, 2014 at 8:59:10 PM | DWG visibility in linked files
craigj
I've got 3 separate files containing 2 buildings and site and have two dwgs loaded in the site model with the line colour overridden to show gray (within site model). When I link the site model in to one building file the lines show up gray as they should, yet when I load them in to the other building, they show black. I try to override the line colours in the "black line" file under RVT Links>Custom>Import categories which does not seem to work. I can override the line colour only by selecting half tone but that does not solve the problem. I've tried copying the view template from the file that has the correct line visibility but that does not work either.
Mon, Nov 10, 2014 at 9:00:17 PM | DWG visibility in linked files
craigj
Also I am using Revit 2014.
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:43 AM
Controlling visibility in linked RVT files
Tue, Apr 18, 2006 at 1:29:10 AM
Linked DWG Files not visable in RCP
Mon, Oct 19, 2009 at 1:46:58 PM
visibility problem with linked files
Thu, Sep 11, 2008 at 11:52:11 AM
Retain visibility if the linked dwg's are updated outside REVIT
Fri, Nov 9, 2007 at 10:14:52 AM
Page generation time: 1.3043
