Forums >> Revit Building >> Technical Support >> Change standard section (or any other name) view name
Mon, Nov 10, 2014 at 6:06:45 AM | Change standard section (or any other name) view name
Factor
How can I change standard name of new created view? F.e. if I create a section, it is automatically named Section 1. I can rename it afterwards but any new created view will be call Section x again. How can I change it just once, so I don't need to rename those views each time?
I know that this is possible because I have one template, where whenever I create a section it is being called "Řez A-A". I though maybe it's because the template was created using standard czech template but after I installed chezh language pack, I started new project using czech template and new created section view was called Section 0 (not even Section 1). Then I starded new project without any template and sections were called Řez 1 (not Řez A-A). So there should be some place to change those names...
Thu, Nov 13, 2014 at 9:02:09 AM | Change standard section (or any other name) view name
Factor
anyone? ;/
Thu, Nov 13, 2014 at 9:17:54 AM | Change standard section (or any other name) view name
We rename it everytime.   I think that is the normal process.
Tue, Nov 18, 2014 at 1:23:31 AM | Change standard section (or any other name) view name
Factor
But I need to prepare a template for future clients and it should be clean and in Lithuanian...
Tue, Nov 18, 2014 at 12:50:48 PM | Change standard section (or any other name) view name
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You cannot preset new view names. End of story.
Tue, Nov 18, 2014 at 1:38:38 PM | Change standard section (or any other name) view name
Factor
After my research I thought the same but as I said, I have one template in which names of sections are called in czech. I downloaded czech revit to check if it's standard in that revit and it wasn't. So someone changed it. or maybe it was in older versions of revit, so someone just updated the template and naming of sections stayed... So I'll leave it like that for this time... Thanks ;]
saving and loading a section or detail to and from a library
Mon, Dec 3, 2007 at 9:12:07 AM
Toposurface Fill Color in a Section View
Fri, Jan 30, 2009 at 9:28:10 AM
Section cut disappears when I change the view range in plan view.
Tue, Oct 28, 2008 at 3:50:07 PM
Section Tail
Thu, Jun 21, 2007 at 3:22:22 PM
Trouble with Creating a Standard Detail [ 1 2 ]
Fri, Dec 20, 2013 at 6:49:09 AM
15
Page generation time: 4.5131
