Forums >> Revit Structure >> Technical Support >> Connections in steel frames
Sun, Nov 9, 2014 at 11:16:02 AM | Connections in steel frames
Profiil
As I'm starting to model simplier steel frames with bracing  then I would like to have a bit of informatsion first.
Should I model the connection plates and bolts into the steel beam and column family of I should add them by connection elements by hand?
I understand that I could do different variations and changing their visibility but is it worth the efford?
To summarize, what is the best practise
a. make separate elements which I add into the beams and columns later on (takes time and not so innteligent)
b. Integrate them into the beams and columns and simply play with the visibility setting (takes model a bit bigger)
Not an Autodesk Subscriber, so no detailing tools for me.
Thank you guys
Tue, Nov 11, 2014 at 2:44:10 AM | Connections in steel frames
ronmalit
5 Stars: 3 Votes
if there is no requirement to model plates and bolts (3D), i would suggest to use detail components (2D).
it can also be parametric, constrained and therefore intelligent.
you can also integrate detail components into beams and columns and play with the visibility
Revit 2018/2019 Steel Connections
Thu, May 10, 2018 at 8:05:17 AM
Steel connections material
Mon, Nov 26, 2018 at 9:30:44 AM
steel frames
Tue, Apr 19, 2005 at 5:50:35 PM
Precast embed connections
Wed, Jul 30, 2008 at 11:22:13 AM
Structural Connections / Mechanical Fixings
Tue, Nov 10, 2009 at 4:20:53 AM
Page generation time: 1.7629
