37 Users Online (35 Members):
Forums >> Revit Structure >> Technical Support >> Armature radius too high - Model explodes - why? HELP. (see attached file)
Hello,
So me and a colleague are working on designing a tensile membrane structure. There is a column and 4 beams coming out of the structure. We are modifying the dimensions to match the spec. However when we change the beam (armature) radius to its rightful value of 31330mm, the model sort of blows up? I dont know what's happening here, can somebody help??
Kay.
Kam |
You can try putting the value of 31330mm in as well, and see if it does the same thing
Kam |
Linked file model missing attached detail group |
Mon, Aug 17, 2009 at 8:26:38 AM
Need a high-rise model shell file |
Sun, Dec 9, 2007 at 4:58:36 PM
Need help creating a sloped slab with Radius Edge |
Tue, May 2, 2006 at 5:23:52 PM
Radius window jambs |
Fri, Jul 6, 2007 at 8:55:13 PM
Get the Radius of a Circle (model line) |
Thu, Feb 9, 2012 at 9:12:58 AM
