Forums >> Revit Structure >> Technical Support >> bell ftg / thickened slab line visibility
Fri, Nov 7, 2014 at 11:35:43 AM | bell ftg / thickened slab line visibility
drafter60
I have created a trapazoidal shape which is applied to a model line @ an interior wall base as a slab edge. The ftg comes in well and in plan shows four hidden lines - two at the top of the bevel and two @ the bottom. Revit shows this correctly, but I'd like to show only the two bottom lines. Any ideas?
Fri, Nov 7, 2014 at 11:36:43 AM | bell ftg / thickened slab line visibility
Use your linework tool - invisible ine.
Edited on: Fri, Nov 7, 2014 at 11:42:38 AM
Mon, Nov 10, 2014 at 11:17:46 AM | bell ftg / thickened slab line visibility
drafter60
Thank you that did the trick.
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:13 AM
Rebar in a thickened slab Revit 2012
Thu, Dec 29, 2011 at 6:40:29 AM
Thickened slab appearance
Fri, Jun 8, 2012 at 10:43:23 AM
Modeling thickened slab strip under bearing walls
Thu, Feb 5, 2015 at 1:13:00 PM
Thickened slab at stoops
Sun, Sep 25, 2005 at 6:39:41 PM
Page generation time: 1.1652
