Forums >> Revit Building >> Technical Support >> Store front wall types done appear
Fri, Nov 7, 2014 at 7:22:51 AM | Store front wall types done appear
SteveB
3.5 Stars: 5 Votes
in a project i've created from a template (that I also created) i want to use a "storefront" wall type and no such walltype exists in the wall pull down.  how do I add storefront and exterior glazing wall types to this project?  I tried transfer project standards/wall type from a project that has them, no go.
Fri, Nov 7, 2014 at 9:08:55 AM | Store front wall types done appear
There is always at least one curtainwall type available, maybe yours was renamed.  Whichever one you have, create a new type from that for your needs.
Fri, Nov 7, 2014 at 9:17:19 AM | Store front wall types done appear
SteveB
3.5 Stars: 5 Votes
WWHub - can do, thanks.
What folder has the mullions families?  I need to load them separately too.
Fri, Nov 7, 2014 at 9:32:58 AM | Store front wall types done appear
Please read your HELP on storefronts: http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-BBC16AF1-88C1-4B2E-A23A-917C3F427E97
Storefront and curtainwalls are created the same and use the same components.  The mullions are still just a rectangle, different size and different panel location but the same families are used for the model - just alter the type.   For detail views, you replace the model elements with detail elements.
store front location in wall
Thu, Sep 3, 2009 at 1:29:06 PM
Store Front Door
Thu, Apr 17, 2008 at 1:22:43 PM
Store Front Windows/doors
Wed, Jul 26, 2006 at 9:35:56 PM
doors in storefront
Mon, Jun 11, 2012 at 10:38:57 AM
How do you add wall types in a project
Mon, Feb 6, 2012 at 1:47:03 PM
Page generation time: 0.5681
