Forums >> Revit Building >> Technical Support >> Tubular Skylight / Light Projection / Building Construction
Wed, Nov 5, 2014 at 4:57:37 PM | Tubular Skylight / Light Projection / Building Construction
carabridget
I'm trying to create a building that uses no electricy and therefore am using tubular skylights for light. However, I'm not sure the best way to put them into the building as the roof is slanted. See attached what I have done. As you can see, there is a gap between the roof and the ceiling. I've cut openings in the roof, and ceiling, but I need the light to be contained in those openings. Anyone have a suggestion of the best work around? Should I be adding something to the skylight family or somehow adding a tube in the building?
Thu, Nov 6, 2014 at 8:28:07 AM | Tubular Skylight / Light Projection / Building Construction
Model like you build....
Would the containers be part of the skylight or ceiling?   No
Would they be like one sided walls?   Yes if square.
You say tubular.  There are ductwork like connectors for some of these skylight like these:
http://www.westsidewholesale.com/velux-tsr-010-0000.html?keyword=Google_Shopping&mr:trackingCode=A1F79F34-BD78-E311-AC1D-BC305BF933C0&mr:referralID=NA&mr:device=c&mr:adType=pla&mr:ad=56683013965&mr:keyword=&mr:match=&mr:filter=88623978565&gclid=CPmU3b2X5sECFUsV7AodCjEA9w
So I would suggest you model something like that.   It would be best if created as a family with a variable top angle and height.
need to make a tubular steel framed structure
Fri, Apr 13, 2018 at 10:13:30 AM
why my projection lines overlap cut lines.
Tue, Apr 10, 2018 at 7:41:07 PM
Horizontal Tubular Structure with floor
Wed, Aug 16, 2017 at 2:19:20 PM
Skylight shaft
Tue, Sep 2, 2014 at 4:03:45 PM
No light inside building
Thu, Mar 29, 2012 at 3:52:35 PM
Page generation time: 1.3389
