Forums >> Revit Building >> Technical Support >> Visibility Projection and Cut lines.
Wed, Nov 5, 2014 at 1:46:53 PM | Visibility Projection and Cut lines.
mskin
I have existing space with a new ceiling.  The existing walls are shaded.  I cant see the projection lines of my ceiling through the cut lineses of the wall as they occupy the same space.  is there a way to override this? so my ceilings edges take precedence over the wall cut lines - even though they are beyond the cut plane?
thanks
Wed, Nov 5, 2014 at 1:55:03 PM | Visibility Projection and Cut lines.
I suggest you change the setting for the projection lineweight of the ceiling.
Remember, you can / should use view templates.  In a RCP, we always back off the wall / cut lines ikn our template.
projection vs. cut lines
Mon, Oct 31, 2005 at 2:29:38 PM
why my projection lines overlap cut lines.
Tue, Apr 10, 2018 at 7:41:07 PM
Toggle cut and projection lines
Tue, Mar 6, 2012 at 6:57:56 AM
Projection and CUT
Sat, Nov 24, 2012 at 5:06:59 AM
Phasing: problem with new doors in existing wall joint lines
Mon, Sep 19, 2011 at 4:32:08 PM
Page generation time: 1.2074
