Forums >> Revit Building >> Technical Support >> associate parameters in nested family problem
Wed, Nov 5, 2014 at 12:45:47 PM | associate parameters in nested family problem
Spirited
I am attempting to make a family for an angled wall to enable the use of curtain wall at a slope.  Am attempting to follow a blog from waterman.blogspot.com.au. I have created a metric profile and dimensioned a line and set a parameter a type.  I have then made a generic wall based model into which I have loaded the profile.  I have made a parameter in the host family with the same name as that in the 'child', but as an instance with 'reportable' ticked.  Both are of 'length', stored under 'dimensions'; their attributes appear to be correct.
When I attempt to associate them I receive the msg:
A reporting parameter can be associated to Element property only if its dimension references Are all to host elements in the family.
and no association can occur.
I don't understand the error msg and would appreciate assistance.
Wed, Nov 5, 2014 at 12:54:22 PM | associate parameters in nested family problem
I think you have it backwards.... The host parameter controls the child - not the other way around.   Can a parameter pass from the child to the host?   I have never checked but all parameters that are passed have to be type based parameters anyway.
Reference to nested family
Wed, Sep 21, 2022 at 7:49:43 AM
Nested family parameters
Mon, Aug 3, 2015 at 12:12:54 PM
Nested family always vertical?
Mon, May 16, 2011 at 2:55:02 PM
Nested family: no option to choose the little button
Mon, Jul 27, 2015 at 9:11:37 PM
Edit Parameters of Nested Family from Project
Tue, Feb 2, 2016 at 8:54:40 AM
Page generation time: 0.9501
