9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Outlet Visibility Above Cut Plane
4 Posts No Rating |
We are documenting wall eelctrical outlets in a fitness center. The outlets occur above the cut plan, so they do not appear on the floor plan. Does anyone know a simple way (not plan region, as this requires too much management) to accomplish this?
Edit the family and have symbolic lines that can sit below the actual family.
If the outlet family has a vertical invisible line that is added to it that is long enough to be cut by your view cut plane, then the outlet will show. << I really don't like this process but it will work.
I don't understand why you don't want your view cut plane to be set hight enough to see these outlets. Think in reverse - add a large plan region to bring the rest of the view back down if you have to.
Outlet families |
Tue, Jul 17, 2007 at 11:49:40 AM
Controlling window visibility |
Tue, May 12, 2009 at 12:49:39 AM
Cut Plane display issue |
Tue, Oct 11, 2011 at 12:48:42 PM
Problems with visibility of Header and door openings |
Fri, Jul 26, 2013 at 11:05:23 AM
How to control where the cut plane is for families? |
Sun, Nov 22, 2009 at 10:19:59 AM
