Forums >> Community >> Newbies >> Realistic View vs. Rendered View
Tue, Nov 4, 2014 at 10:28:07 PM | Realistic View vs. Rendered View
dbegalske
Trying to put a dark brown shingle roof on a building. Selected Asphalt Shingles (basic gray color), went to Owens Corning website and did a save as on a nice dark brown shingle pattern. Changed image files to the new (dark brown) in both the Appearance - generic and the bump locations.
The realistic view shows a nice dark brown set of shingles but the rendered image still shows as gray? How do I get the rendered view to match the realistic view?
Thanks,
David
Wed, Nov 5, 2014 at 7:13:14 AM | Realistic View vs. Rendered View
This is different for different issues of Revit so what Revit are you using?
Wed, Nov 5, 2014 at 7:27:17 AM | Realistic View vs. Rendered View
dbegalske
I am running Revit 14 at home and Revit 15 at work.
David
Wed, Nov 5, 2014 at 7:41:26 AM | Realistic View vs. Rendered View
Revit changed how materials are handled in the 2013 release.   Here is a good written explanation of the process:
http://www.cadalyst.com/cad/revit/understanding-autodesk-revit-materials-17422
Walkthrough in realistic view, not rendered
Wed, Aug 27, 2014 at 12:00:38 PM
Revit tree not showing shadow in realistic or rendered view
Fri, Mar 18, 2016 at 10:37:28 AM
Vegetation in Realistic View Setting
Wed, Apr 4, 2012 at 8:14:27 AM
Material Viz Control in Realistic Plan View
Mon, Jul 14, 2014 at 7:32:30 AM
Can't see through ghosted Surfaces when view is rendered?????
Wed, May 25, 2011 at 11:33:06 AM
Page generation time: 2.0903
