Forums >> Revit Building >> Tips & Tricks >> multi-category tag
Tue, Nov 4, 2014 at 2:58:32 PM | multi-category tag
palowe
Hi everyone,
I have a toilet component classified with type mark X. But also inside this toilet component i have as a component the flushometer also classified with type mark Y. Now in the project when i say tag all it tags the toilet but it doesn't show me the tag for the flushometer, and doing manually tag i can't catch it either.
Any suggestion?
Funny thing is that for some toilets it does show me both tags (toilet & flushometer) i can't see a difference in between them that would be reason.
Thanks,
Tue, Nov 4, 2014 at 3:22:00 PM | multi-category tag
In order to tag a nested family, it has to be set to shared.
From your HELP: "A family that contains nested and shared families works as any other family within a project. However, you can press Tab to toggle to the nested and shared components."
Wed, Nov 5, 2014 at 10:09:56 AM | multi-category tag
palowe
The flushometer family is set to shared
Wed, Nov 5, 2014 at 10:28:38 AM | multi-category tag
Was the family shared when it was placed in the host family?  If not then it will not tag.
Check out this and see if his process helps you:
http://revitrants.blogspot.com/2013/03/tag-all-with-shared-nested-families.html
Wed, Nov 5, 2014 at 12:21:29 PM | multi-category tag
palowe
It doesn't work still...
Thanks anyway
Wed, Nov 5, 2014 at 12:28:42 PM | multi-category tag
Post the host family .... let us look at this.
BTW - Are you sure the nested family is the correct category for the tag you are trying to use?
Wed, Nov 5, 2014 at 12:42:01 PM | multi-category tag
Did you ever try to just place the shared family in your project and tag that with the same tag.  In your schedule, do these type marks show up for these two items in the same column.   There are a lot of families that are poorly built.  Each of these families may have a parameter called 'type mark' but that doesn't mean they are the same shared parameter.   Shared parameters are a lot more that just their name.
Wed, Nov 5, 2014 at 5:05:18 PM | multi-category tag
palowe
Yeah, if i insert the nested family itself it would tag
Edited on: Wed, Nov 5, 2014 at 5:16:32 PM
Thu, Nov 6, 2014 at 7:44:27 AM | multi-category tag
Your problem is how this 2-1/2D family was built.   There is NO flushometer family visible in your plan.   That family is turned off in plan view and symbolic linework was created in the host family.   That just won't work.
You have to set the visibility in the flushometer family and not in the host.
Thu, Nov 6, 2014 at 8:09:45 AM | multi-category tag
palowe
It did tag finally. Thank you sooo much
Problem with Multi Category tag
Mon, Apr 3, 2006 at 12:48:41 AM
Multi category tag in Revit 8.
Mon, Mar 27, 2006 at 10:33:20 PM
Multi-Category Tag with horizontal leader lines - RAC 2012
Wed, Feb 15, 2012 at 4:29:14 PM
Space "number" parameter to Multi-Category Tag?
Fri, Dec 13, 2013 at 10:26:02 AM
Leader Line Line weights
Sat, Feb 7, 2009 at 7:26:00 AM
Page generation time: 0.3000
