15 Users Online (13 Members):
Forums >> Revit Systems >> Technical Support >> Schedule with formula. Yes/no --> Show
Hi
Want to hear if it's possible to make a formula in a schedule where on of the colums is based on a yes/no parameter combined with another parameter.
To describe it:
I have a schedule where i want to show the difference between the top of the column, and the top of a console. The column has three console whit a yes/no parameter on the family. So it's it not every time i want every three consol in the schedule, it depends on the column, I know the the hole bar of the schedule will be visible. But for every different column if would like only to show the value between top cokum and yop console based on the yes/no parameter.
In the picture you can she witch figure i would like to show in the schedule (red box), with the other ones are just an emty box.
Hope every one understand.
Not possible as I read your question.
That was also my conclusion. I have found a solution, but thanks any way.
hi there,
i am an amature in Revit . i would like to have an answer for my problem issue here . when i am creating a schedule for families , it will not give me the total count of the family in the column . please find the attached image.
please advise
thanks
SCorpion - You should learn to create a new thread or find an appropriate thread that matches your question. You can find your answer here in your Help. Learn to use that.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-A31811A6-D02B-498D-9AF9-4CA3DDB18A7F
Calculated totals of formula in schedule |
Fri, Sep 11, 2020 at 7:14:07 AM
Schedule Parameter formula not showing up [ 1 2 ] |
Thu, Oct 28, 2010 at 4:33:57 PM
23
Adding Dots to the Door Schedule |
Fri, Dec 2, 2011 at 5:41:20 PM
Revit schedule formula |
Mon, Jan 26, 2009 at 3:05:31 PM
Ceiling Height, Formula Field in Schedule???Possible or not??? |
Tue, Nov 3, 2009 at 10:27:51 AM
