19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Sketch/Family Constraints
7 Posts No Rating |
Hello,
I am using Revit 2014. I have created a parametric louver family, but am running into one last issue. The louver's width and length can be controlled, and also the quantity of fins within the louver. However, I am trying to get the length of the fins to change with the length of the louver. For the fins, I have a parameter set up that is called 'Fin Length" that subtracts 4" from the overall length (for the 2" frame on both sides). The fins are created by a sweep and whenever I try to lock the ends of the sweep's path to these reference planes, I get the error below and it won't lock.
You may not create sketch or family constraints between group members and elements which are not members of the same group.
Do I need to make a separate family for the fins? Any ideas?
Thank you!
I'd say yes, Nest the fin family.
7 Posts No Rating |
Thanks for the reply. I still cannot get the length of the fin to stretch/skrink with the length of the overallparameter.
parametric extrusion sketch |
Wed, Mar 7, 2012 at 9:48:33 AM
Family Type Constraints |
Thu, Jul 5, 2012 at 10:55:10 AM
Creating a JOIST Family |
Tue, Nov 5, 2013 at 3:07:33 PM
Default Constraints in window family |
Fri, May 4, 2012 at 7:13:48 PM
11
Sketch up |
Thu, Mar 15, 2007 at 6:46:50 PM
