13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> Shared Parameters over two separate central files....
I'm trying to create an electrical/mechanical coordination schedule with editable parameters. I've done this with a single MEP central file. However, I'm not sure if this can be done over two separate central files (one electrical and one mechanical).
The shared parameters are loaded into the mechanical family, project parameters and schedule. The parameters are set to a common discipline, text and 'instance' but it's still not editable.
Here's the strange thing. The 'Type Mark' and 'Location' are being filtered through fine on the schedule. But the other parameters are not.
Any ideas?
In order to change any element's parameter, you have to own the family..... The family has to be in your file. (Copy monitored families are owned because they are a copy)
How to permanently purge Shared Parameters easily(without API access)? |
Mon, Nov 23, 2020 at 1:00:39 PM
Shared Parameters Text File? Has anyone used this? |
Tue, Jun 14, 2011 at 10:11:56 AM
Saving Elements to Separate Files |
Thu, Feb 18, 2010 at 4:00:28 PM
Shared Parameters |
Thu, Feb 9, 2006 at 1:41:58 PM
Newbie trying to understand central files vs. import revit files |
Tue, May 5, 2009 at 6:55:03 AM
