27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Width factor as a parameter
Revit 2013
Hi all. Is there a way to make a parameter out of the width factor of a text label?
No - no matter what you seem to mean.
Width factor ? Of the letters - no
Of the label area ? Set when you lay it out.... if you need options, have multiple label text areas of different widths set up using different parameters to switch the correct one on and the others off. .... or have multiple label families.... like 'Room Name Wide' / 'Room Name Narroe' .... OBviously they you may also want to have different width text for each of those.
Thanks WW. I'm trying to make a titleblock family and the sheet number for this titleblock would have the width factor parameter. We need an adjustable width factor because certain sheet numbers are longer than others, thus requiring a smaller width factor. We can make all the sheet title width factors the same, but then the sheets with shorter names look too skinny.
Not a problem Create another titleblock or titlebock type as I have written above.
Text Box Width Factor Masking Error |
Wed, Mar 18, 2015 at 2:33:50 PM
text width factor for dimensions |
Thu, Apr 20, 2006 at 7:44:21 AM
Model Text Width Factor?? |
Tue, Feb 17, 2009 at 2:10:48 PM
Can you adjust the text width for dimensions? |
Thu, Oct 27, 2005 at 5:20:00 PM
occupant load factor |
Fri, Oct 14, 2011 at 10:31:08 AM
