15 Users Online (13 Members):
Forums >> Community >> Newbies >> Wall Joint
Hey All.
I m new to Revit and I m just modelling a house and try to make things work as they should be !
Now I came to a thing that I cannot solve either through a tutorial or any book or so.
I got a wall with brick, as external wall and another external wall with render. The render wall is
joining into the brick in a 90 degree. First problem is: How can the brick wrap around the insulation
completely ? I know there is wrap in the type setting but is just wraps partly. Second problem.
The external wall has a an internal side that is finished with render and another that isn t as its only outside.
How do I get rid of the wall finish on the front bit ? Hopefully anyone can help me, its really appreciated.
Kevin from London
ps. I ll attach an image
The end wall - your problem is that inside layer.... you will have to use a short wall here that does not have that layer. Then the outside wrap will work.
BTW - Read this chapter in your HELP:
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-1CCD1005-CBDA-4338-8D60-489095D4BB25
Thanks a lot WWHub !
It now worked and the chapter in the Help is what I needed.
How do you hide the joint lines between different wall types? |
Fri, Nov 16, 2007 at 8:16:34 AM
Creating an expansion joint family |
Sat, May 2, 2009 at 10:57:03 AM
newly created wall footing won't joint |
Mon, Nov 3, 2008 at 10:02:11 AM
Curtain Wall Issues_Edge Joint |
Fri, Jun 1, 2007 at 1:36:41 PM
wall joint in plan view |
Wed, Feb 16, 2005 at 10:50:01 AM
