Forums >> Revit Building >> Technical Support >> REvit 2015 - Family Library (Windows)
Wed, Oct 29, 2014 at 9:51:21 AM | REvit 2015 - Family Library (Windows)
Calman1993
5 Stars: 2 Votes
Hello,
I'm wondering if anyone can help me, the windows in revit don't seem to be working properly. (please find image attached) - can someone tell me what is up, this has happened with the double - all bars and the double plain.
Please can someone advise me of the problem?.
Many Thanks
Wed, Oct 29, 2014 at 10:02:59 AM | REvit 2015 - Family Library (Windows)
The windows in Revit work fine.   Any windows built by someone else may not work correctly.   We don't have a clue what window family you are using because you don't tell us, therefore, there is no way to help you.
Wed, Oct 29, 2014 at 10:08:14 AM | REvit 2015 - Family Library (Windows)
Calman1993
5 Stars: 2 Votes
This is the standard Revit Content Library - Windows, i have tried a couple and seem to have something missing, i have not adapted these in anyway.
Wed, Oct 29, 2014 at 10:17:41 AM | REvit 2015 - Family Library (Windows)
I have no problems with the 2015 windows..... AGAIN _ WHAT WINDOW?
I don't understand .... we work in a profession that requires good information.  Ask your questions better by providing enough information.
Wed, Oct 29, 2014 at 10:27:33 AM | REvit 2015 - Family Library (Windows)
Calman1993
5 Stars: 2 Votes
It's not all my windows, it is only a couple from the Content Library - Which would be the Double All Bars, Double Plain & Double Variable Casement windows that i have tried, it's like a parameter is missing from it or there is some sort of corruption, I apoligise if i'm not making sence, but the windows worked fine the other week, and only today will not.
These windows  were not made by me, but Revit itself, that means there must be a problem with my Revit program or the Revit Library somewhere.
Wed, Oct 29, 2014 at 10:47:28 AM | REvit 2015 - Family Library (Windows)
Sorry - The windows you are using are NOT in the stock library.  Snip list is below.  Someone has either added some bad families to your library or you are using a different library that you have not told us about.   I'm in the US Emperial Library.
If you would post one of the families, we might be able to tell you what is wrong with the family.  Also include your wall thickness.
Edited on: Wed, Oct 29, 2014 at 10:48:08 AM
Wed, Oct 29, 2014 at 10:58:25 AM | REvit 2015 - Family Library (Windows)
Calman1993
5 Stars: 2 Votes
I'm Using the UK Library - Ill post one of the family.
I can ensure you that these windows are downloaded with Revit.
Wed, Oct 29, 2014 at 11:03:19 AM | REvit 2015 - Family Library (Windows)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The family does not work right, it is not built well.  I don't know where you got these but they are not downloaded with my version of Revit
Wed, Oct 29, 2014 at 12:25:50 PM | REvit 2015 - Family Library (Windows)
That family doesn't even look right in the family editor.   It also doesn't flex when you change types.  I doubt very much that this was in the stock UK library.
I suggest you fine a different window because this one has a lot of problems.  Check out Autodesk seek.  You may have to change the units to work for you but the commercial windows on seek will flex correctly.
Tue, Nov 4, 2014 at 9:57:34 AM | REvit 2015 - Family Library (Windows)
ukchap
I am also having the same issue with UK content fresh out of the box - first project I have done with 2015. Looks just like the image you have posted.
Tue, Nov 4, 2014 at 10:05:17 AM | REvit 2015 - Family Library (Windows)
#11
Complain to Autodesk.
Revit 2015 Missing Family Template Files
Thu, Nov 13, 2014 at 6:45:25 PM
managing revit content library
Thu, May 3, 2018 at 8:37:26 AM
Revit 2015 Dimensioning
Tue, Jul 15, 2014 at 7:44:54 AM
Windows and Family Editor Query? Help please! :)
Wed, Apr 9, 2008 at 11:18:06 AM
Cannot Load Components from Library
Wed, Jun 1, 2016 at 6:31:16 AM
Page generation time: 1.7079
