Forums >> Community >> Newbies >> Revit Camera creation from a view
Tue, Oct 28, 2014 at 3:11:40 PM | Revit Camera creation from a view
kenyhel
I am aware that in 3ds max if you find a view that you like you can change that view from a perspective into a camera view.  This can be seen as discribed on this link
http://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/3DSMax/files/GUID-357BE338-6CCE-403B-B719-17B13A72B442-htm.html
My question is how can this be done in revit?
Mon, Nov 3, 2014 at 6:44:19 AM | Revit Camera creation from a view
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hi Kenyhel,
Have you tried orientating to view?
On the camera view, beneath the cube, click the arrow and select "Orient to View" then "3D Views" and select the view you want the camera to orient to. See attached.
Hopefully that was what you were after.
Kind Regards,
Shatner
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Materials in a camera view
Mon, Mar 25, 2013 at 8:17:41 AM
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 1:12:58 AM
Camera lens adjustment
Sat, Sep 9, 2006 at 12:03:58 PM
scaling camera view on sheet
Fri, Nov 8, 2013 at 11:30:59 AM
Camera View not showing demolition lines dashed
Wed, Dec 11, 2013 at 2:24:15 PM
Page generation time: 2.5588
