Forums >> Revit Systems >> Technical Support >> Revit 2015 has stopped working.
Mon, Oct 27, 2014 at 11:36:15 AM | Revit 2015 has stopped working.
shannon712
I have no idea how or why, but Revit 2015 won't open for me and I get the message "Revit has stopped working".  Any ideas how to fix this?  I found an old thread with the same issue involving Revit 2010 and the solution seemed to be do delete the file "WSCommCntrData.xml"I don't know if the sulution is the same here, but I cannot find the equivalent R2015 file on my computer.  Any help will be apprecieated.
Here is the link to the 2010 thread for reference.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=21533
Mon, Oct 27, 2014 at 1:57:47 PM | Revit 2015 has stopped working.
I don't know where that file is in 2015 either ... or if it exists.  We have not seen any recent postings on this.  Have you installed Revit2015 with all of the updates?
There is another file that is sometimes problematic:
C:\Users\<USERNAME>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2015\UIState.dat
Rename that file, restart Revit and see if it helps when Revit rebuilds it.
Otherwise you may have to ask your re-seller.
revit 2010 has stopped working
Wed, Apr 3, 2013 at 9:31:29 AM
Spell Check stopped Working
Mon, Oct 5, 2015 at 6:38:39 PM
CutePDF stopped Working. Any alternatives?
Mon, May 3, 2021 at 7:35:28 AM
Revit 2015 Dimensioning
Tue, Jul 15, 2014 at 7:44:54 AM
Point Cloud in Revit 2014 no longer working in Revit 2015
Fri, May 15, 2015 at 3:23:06 AM
Page generation time: 1.6581
