Forums >> Revit Structure >> Technical Support >> selecting structural walls
Mon, Oct 27, 2014 at 2:19:44 AM | selecting structural walls
solidsnakeala
hi, using revit 2014 ,
is there a way to select all the structural walls together??? plz help
Mon, Oct 27, 2014 at 7:31:29 AM | selecting structural walls
You can filter views to show walls by structural usage.
Mon, Oct 27, 2014 at 7:34:17 AM | selecting structural walls
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
When you change the view discipline to structural, only structural walls will be displayed making easy to select them. You can also set up a filter based on a structural usage to hide all non-bearing walls.
edit: ah, ...you're too fast for me WW Smile
Edited on: Mon, Oct 27, 2014 at 7:36:47 AM
Mon, Oct 27, 2014 at 8:20:41 AM | selecting structural walls
pijpiwo - Your discipline answer was the better answer.
Wed, Oct 29, 2014 at 8:03:24 AM | selecting structural walls
solidsnakeala
Thanks Guys, actually the filter method was usefull .
Selecting-De-selecting objects.
Fri, Nov 25, 2005 at 10:12:01 PM
Shading Structural Walls
Mon, Nov 21, 2011 at 11:21:46 AM
structural usage for stacked walls
Tue, Jun 30, 2015 at 6:59:56 PM
structural wall VS structural columns
Tue, Apr 26, 2016 at 3:49:39 PM
Can't view structural walls on second floor- any help?
Mon, Mar 11, 2019 at 3:16:58 PM
Page generation time: 0.3806
